programatically controlling vi properties
So Mike, are you out of hibernation... ?! Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 11 of 14
(1,094 Views)
Hey Partha,
seems like that. 🙂
Greetings
Mike
Message 12 of 14
(1,093 Views)
hi Mike,
can you demonstrate in an example how to use this property progrematically?
Rafi
Message 13 of 14
(1,069 Views)
Hi Rafi,
the attached image shows both possibilities. Depending on what you want to do, you should deside if you use the property or the method. If you use the method to hide a vi, then it's better because it has still a valid windows handle.
Hope it helps.
Mike
Message 14 of 14
(1,065 Views)
