programatically get specific ivi-driver attributes ......
Hello all together!!!
My Problem is the following:
I want to run different Arbitary Waveformgenerators from differnent Vendors. All have IVI-C Drivers.
But I need to configure them differently. One has a filter one not, one Sync need to be activated programatically one not,.... and so on......
So the idea was, to obtain these informations from the driver like Labview does. Because: When placing an property node and "select class/ivi/ivifgen" the property node has all options available from the driver.
Can I do this programatically? I mean, can I get all the attributes; attribute name; the datatype; the options for a ring; ......
So I could build a interface, wich could handle all known Instruments very fast an easy.....
And do not have to do the workaround for each Instrument.
Or is there a good alternative to this aproach?
With regards to everyone and Thanks for helping
Bernhard
Message Edited by teddy 150 on 06-02-2006 12:33 PM
Message 1 of 1
(2,498 Views)
