programmatically change fields in application
I have to make testsoftware but I need to controll several application manually to test it.
How can I change a field of an application that is running.
This application is not labview.
eg. notepad is running and I want to enter a text in notepad only by my labview application.
gr,
Message 1 of 10
(4,341 Views)
If you want to control Notepad, I think you'll need ActiveX or something similar.
One quick search hit this page: http://forums.devshed.com/html-programming-1/opening-notepad-w-activex-1336.html
Patrick Allen: FunctionalityUnlimited.ca
Message 2 of 10
(4,331 Views)
Do you really need to use Notepad or can you simply modify the file directly in LabVIEW? I imagine that you are trying to change a configuration file for a device and therefore you should be able to directly modify the file through LabVIEW using the file and string primitives.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 10
(4,327 Views)
Well the situation is this.
I need to automate a test which is now manual input.
It is not notepad I want to use, that was merely an example(maybe bad example)
So I first call the 'application' which comes from the customer.
Then I want labview to enter severall fields in the 'application' and also activate some buttons.
Note this application is no labview application, also don't have the source.
I did search the internet for the 'handle' subjects but no result in what I need.
Message 4 of 10
(4,315 Views)
You might want to check out the free program called "Auto It".
It's designed to do what you're looking for.
http://www.autoitscript.com/site/autoit/
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 5 of 10
(4,305 Views)
Hello Steve,
That looks very interresting!
I tried it but there seems no option to retrieve a value from the application.
I also tried to use teststand to do this, when opening a exe I can add a "handle" to it.
Think that I then have to use kernel32.dll to get and put data, but dont know how the function must look like.
Message 6 of 10
(4,300 Views)
I wouldn't hurt to ask your specific question in the Autoit forum, just to be sure.
From the feature list:
"Directly get information on and interact with edit boxes, check boxes, list  boxes, combos, buttons, status bars ..."
steve
Message 7 of 10
(4,286 Views)
Did some testing yesterday.
Now I use a function to move the mouse to a location on de application.(before this I use the function "Blockit" from the user32.dll so that the mouse cannot be moved by the tester)
Then use the function CTRL+c to copy the value to clipboard.
Now I have to find a way to compare the value from clipboard with teststand.
Message 8 of 10
(4,281 Views)
Take a look at this thread. It has examples of reading data from the clipboard.
Mark Yedinak
LabVIEW Champion
Message 9 of 10
(4,266 Views)
All thanx for the reply.
I thought teststand would be able to get the clipboard data somehow but I did not find how.
Special thanx for the link to autoit, really nice program and also free!
Now I made a VI(see below) which makes it now posible to get the clipboard to teststand.
gr,
Message 10 of 10
(4,243 Views)
