using one counter/digital line as a trigger to reset another counter line
Hi I am using a PXIe-6366 device and I am using a shaft encoder which has 3 outputs; 2 outputs, A and B, which produce 720 pulses per revolution (both 90 degrees out of phase) and the third ouput, Z,  is a marker which pulses once every full revolution.
I am using 'A' as counter in my code but I would like to use 'Z' marker to reset the 'A' counter continously. Is this something that is possible?
I came across this picture from the NI site which uses a button to reset the counter - I believe I could use a similar code but just need to replace the button with my Z counter as a trigger
https://decibel.ni.com/content/docs/DOC-6576
For further information this shaft will be run at a max of 3000rpm (50Hz) - and I am not sure if such high speed would be an issue when resetting the counter A line. The PXIe chassis I think also has capabilities of triggering but not sure how to set this in MAX.
Any suggestions? Many thanks
Notay
(2,844 Views)
Accepted by topic author Notay
This is the standard arrangement for a quadrature encoder, although it sounds like you're only using the A channel rather than both A and B.  Take a look at the section labeled "Position Measurement" under Counter Input Applications in your device manual.  Also these two examples may be helpful:
Angular Position Measurement with a Quadrature Encoder
Connect Quadrature Encoders to a DAQ Device
These show how you can use the Z signal to reset the position counter to a specific value.
(2,838 Views)
Many thanks - I actually wanted angular position. I was going to use the counter values and convert them into degrees using simple maths but this does everything for you. Cheers nathand
(2,829 Views)
