programmatically save xls file as pdf
Using Microsoft Report Generation Toolkit to create report.
Client wants pdf file not xls file.
Suggestions for programmatically saving xls file as pdf.
Message 1 of 11
(13,196 Views)
The most used method to create a pdf file is to print the file as a pdf file to some storage media. Using some sort of pdf printer driver.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 11
(13,180 Views)
Hi markfranklin,
You should be able to use Print Report.vi to select a PDF printer (including Adobe alternatives such as doPDF or PDF995). This method would require nothing more than just to have the PDF printer installed, and then adding the VI in your code.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
Message 3 of 11
(13,166 Views)
Imtiaz,
Thank you, yes, I can have a pdf printer as the default printer.
I should have been move specific with needs.
I need to programmatically save as pdf to a custom folder location and custom file name, without a pdf printer popup box.
So the search continues....
Message 4 of 11
(13,160 Views)
Please do a search in the forum. This question comes up quite frequently. The most recent was just a few months ago.
Message Edited by smercurio_fc on 09-28-2009 09:59 AM
Message 5 of 11
(13,152 Views)
markfranklin,
Sorry I did make some assumptions there. I had a look at the low-level code for the Print Report VI and can't figure out a way to modify it to do what you want. Like Coq Rouge said, it would require a pdf printer driver for optimal integration. I did however find a third party PDF Toolkit by Simplicity AI which may suit your needs. It was coded for LabVIEW 8.6 and is available for free download from: http://www.simplicityai.co.uk/products_services/products/pdftoolkit/
I hope this will be of use.
Imtiaz Chowdhury
Project Manager
Message 6 of 11
(13,136 Views)
Here is a tool you may look at. http://excel-to-pdf-converter-pro.software.informer.com/ It is not free, and I have not used it myself. But I found it it my "might be useful" link archive
Message 7 of 11
(13,118 Views)
Accepted by markfranklin
Got excellent solution form Scott at NI - phonebank.
PDFCreator open source freeware + Active X code found at www.ni.com search create pdf.
Note that you will have to go in and update the Active X selection for each of these vi's, quick, easy, and free.
Message 8 of 11
(13,096 Views)
Hi markfranklin,
Did you find this one? Could you please confirm?
http://decibel.ni.com/content/docs/DOC-4552
Adam
Message 9 of 11
(12,946 Views)
Hello List,
Can someone please post the exact link to the Active X above?
Mike
Message 10 of 11
(12,423 Views)
