programmatically trigger button
Hi Guys ,
I have a small question regarding triggering a button programmatically.
Lets take an example :
Suppose I have a OK  button and i want to trigger it programmatically , what should I do , I know value signalling can work , but i am having problem with it , when i give it a boolean value 'True' it says I cannot give value signalling a boolean value.
So my question is how to  trigger the button ?
Thanx
(4,213 Views)
Accepted by OmarTariq
I found it ,
we just need to use value signal  not value signal (signalling) ..
Thanx
(4,190 Views)
I suspect the problem is the Mechanical Action setting of the Boolean.
Value signaling is only support with the top row of options from the Mechanical Action menu.
Switch when depressed
Switch when released
Switch until released
Omar
Omar
(4,185 Views)
yes exactly , your right
thanx
(4,179 Views)
