programmatically update currently selected combo box item???
ok sorry. but now i have one more issue. how do i pass the control from the event structure to a case statement in the same loop??? see example.
Message 11 of 13
(1,045 Views)
Its simple.Take event on that control as well.
Place case structure inside it. Do not forget to connect Shift register from left tunnel to right In that event case.Smiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 12 of 13
(1,043 Views)
hmm. ok. the reason i asked is that i already have an existing program with several case statements inside a while loop, and then i was going to add this. but yes, you're right, this is probably the approach i should follow.
Message 13 of 13
(1,040 Views)
