programming conveyor belt speed
Hello Maire
there is a ready to use pid vi in the pallete, also interesting white paper about pid.
I aggree with Borjomy , if the parameters are set correct in the inverter, it should regulate this by itself.
For a better understanding how looks your programm at the moment.
best regards
Alexander
Message 11 of 13
(565 Views)
I'm not sure exactly what a "fractional mill" is, but it sounds like the VFD that's driving it is independent of the one driving the conveyor belt, so I don't follow the folks above who are saying the belt speed should be regulated automatically in the way that the OP wants. It sounds like (generally speaking) you'd need a PID loop that takes the load of the fractional mill VFD as input, has a setpoint that's the desired load on the fractional mill VFD, and produces an output value that controls the output frequency of the conveyor belt VFD.
Message 12 of 13
(559 Views)
I'm really beginning to hope the original poster draws us a picture.
Message 13 of 13
(554 Views)
