programming power supply tti ql355p
hello,
I would like to create a program to use the power supply TTI QL355P which should look like the attached chart.
thanks.
(3,752 Views)
Hi delphi,
welcome to the forum. Smiley Happy
Where are your problems at the moment. Which communication do you want to use? There are many examples about RS232 and GPIB in the example finder.
Mike
Message Edited by MikeS81 on 05-09-2008 10:31 AM
(3,751 Views)
I use USB connection but I am a novice with this equipment. I don't know to do with this power supply to obtain the correct signal.
(3,736 Views)
(3,734 Views)
