progress bar indeterminate state
is there any way to put the progress bar into indeterminate state ? There are times when my program reaches a certain subroutine that I can not tell ahead how long is the maximum bound is going to be ...there has to be a way to do this easily but I just can't seem to find it anywhere.
(4,001 Views)
indeterminate state,
what I meant here is that progress bar should not just idle but constant rocking back and forth the glider with a small block ....very similiar to how you normally see when you use your OS.
(3,998 Views)
Are you talking about windows progress or anything. I am not able to understand. It will be better if you can explain in a better way.
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
(3,989 Views)
Accepted by lavalava
Here's a recent thread with a couple of examples.
___________________
Try to take over the world!
(3,981 Views)
thanks Tst, one of that example was exact what I'm looking for ...minus the rocking backward motion looks pretty cute thanks
(3,950 Views)
