11-22-2025 03:51 AM
If it’s not difficult, could you take a look?
Hello, I wanted to ask if you can help me find an error in this project. I followed the YouTube tutorial exactly until the end, but after completing everything my Process Value (output) and LCV do not work. Could this be related to the version (I have the 2025 version)?https://www.youtube.com/watch?v=BWL9npmaiUg
Solved! Go to Solution.
11-22-2025 10:17 AM
We cannot run or debug pictures. If you need help, please attach your VI.
(Use "save for previous" (2020 or below) and make sure all controls contain reasonable default values.)
11-22-2025 10:33 AM
What happens if you change the zero to some non-zero value?
11-22-2025 10:52 AM
thanks for your answer, i found the solution
