project from youtube
If it’s not difficult, could you take a look?
 Hello, I wanted to ask if you can help me find an error in this project. I followed the YouTube tutorial exactly until the end, but after completing everything my Process Value (output) and LCV do not work. Could this be related to the version (I have the 2025 version)?https://www.youtube.com/watch?v=BWL9npmaiUg
(1,003 Views)
We cannot run or debug pictures. If you need help, please attach your VI.
(Use "save for previous" (2020 or below) and make sure all controls contain reasonable default values.)
(958 Views)
Accepted by topic author a=rtg
What happens if you change the zero to some non-zero value?
(949 Views)
thanks for your answer, i found the solution
(943 Views)
