properly start FPGA lvbitx
hello
if I embed the lvbitx bitfile into the startup.rtexe, does that mean I better delete it from the cRio?
Or just disable "run the vi"? There will not be a vi, when its compiled? As in no connection to Labview?
https://www.ni.com/en/support/documentation/supplemental/09/managing-fpga-deployments.html
Reason I am asking, on cRio boot first FPGA starts, then startup.rtexe. Then my Startup.rtexe seems to start FPGA again, which somehow causes the FPGA to fail. Propably because it throws an error a la "FPGA already running". When I then run my real time host vi, FPGA starts for good and everything works fine.
So if there is no FPGA on cRIO boot, startup.rtexe is run first. This then starts controlled the embedded FPGA just once and it should work?
or stop it and start again with the lvbitx file embedded?
http://zone.ni.com/reference/en-XX/help/372928D-01/capi/functions_session/
Message 1 of 17
(7,762 Views)
FPGA can be set to run from its Build Specification, the Open FPGA VI Reference Function (checkbox), or Run (Invoke Method) from the FPGA interface.
As always check the cRIO Dev Guide (section 5 in this case): https://www.ni.com/en/shop/compactrio/compactrio-developers-guide.html
PS consider using the RAD https://www.ni.com/en/support/documentation/supplemental/12/archive-of-the-real-time-application-dep...
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 2 of 17
(7,755 Views)
Yes, that's correct. You should include the bitfile in your startup.rtexe (this happens automatically through Open FPGA VI Reference) and you should not load the bitfile separately into the dedicated flash memory on the cRIO.
You should load the bitfile to flash ONLY if you need the FPGA bitfile to start running immediately on boot, before the LabVIEW application starts (or if you don't have a real-time application at all, and you only need the FPGA to run).
Message 3 of 17
(7,752 Views)
soemthing like this:
do I have t make sure the built numbers match? Bitfile is 1.1.16 and rtexe is 1.1.17. Can always compile rtexe as 1.1.16, thats faster for testing.
Its cRIO 9074 with 9870, 9871 in scan mode and profibus in FPGA. But it really just comes unstuck, when the FPGA does not start. So I try on Monday.
Message 4 of 17
(7,739 Views)
The build numbers are irrelevant. However, I recommend that each time after you build the FPGA bitfile, you re-select it in the Configure Open FPGA VI Reference dialog box to make sure that it picks up the latest version of the bitfile.
Message 5 of 17
(7,732 Views)
ok. I guess I could also do stop and start FPGA as per this one
this would be great, if it finally works.... Will mark as solution, if it works onMonday.
@terry, I guess the safest bet is, I ftp in. So I see whats there. Then delete lvbitx manually
Message 6 of 17
(7,729 Views)
still no joy. Seems its not just the FPGA.
I made a vi that starts and stops the FPGA from PC host side, that works, FPGA LED on cRio is on/off.
When I start RT host main vi manually, Labview deploys everything and then the cRIO is working. But in the long run its meant to be a compiled version.
The cRio start all ok.rtf shows the cRIO booting,
Startup Application: /c/ni-rt/startup/startup.rtexe
 NI-VISA Server 14.0 started successfully.
Welcome to LabVIEW Real-Time 14.0.1
So the startup.rtexe should have started all the involved vis?
Message 7 of 17
(7,669 Views)
if I make a distributed setup, why is it 17 MB at least in vis, but the startup.rtexe is only 3 MB including 1.3 MB for the lvbitx file. Does it really compile everything?
Could there be issues with identical names for vis? Or names like [RT] Main.vi? Could it be, startup.rtexe cannot find something? It it runs on cRIO boot, but when I deploy it from Labview, it actually works?
Message 8 of 17
(7,662 Views)
Hi Steffen,
Yes, LabVIEW is executing compiled code - always!
Not that I heard of…
Then it would not run at all -  or should give proper error messages you can handle in your code!
That's the point why you should deploy your RTEXE from the IDE!
Message 9 of 17
(7,658 Views)
but then the cRIO can never run without Labview, because rtexe does not execute on bootup? cRIO should be able to run on its own.
I guess I put some markers into that Main vi tomorrow, see how far it executes.
Message 10 of 17
(7,653 Views)
