properties of a knob not staying fixed
I create a knob with representation I8.
I want to limit the data range to integer values of 0 to 7.
Furthermore, I want text labels for the 8 values.
I go to Properties/Data Range and set the minimum to 0 the maximum to 7 and the increment to 1.  I carefully turn off the "Use default range" check box.
I go to Properties/Text Labels.  I enter my 8 text lables one for each of the numeric values.  I carefully turn off the "Use Sequential Values" check box.
I click OK.  I look at my masterpiece.  It looks beautiful, just the way I want it.
Then I run the program.  Only the first and last text labels on my knob are shown.  When I go back to Properties/Data Range the range has been reset to 0 to 127. When I go to Properties/Text Labels the Use Sequential Values checkbox has been turned back on.
What is going on here?
David
(2,509 Views)
Is there any chance that there are property nodes modifying this in your code?
Can you post an example of this?
___________________
Try to take over the world!
(2,498 Views)
Thanks. I found it. I was indeed resetting properties programmatically. I'm a little bit embarrased that I didn't find it myself.
David
(2,488 Views)
