pulse led for 100ms
i have an incoming boolean state, when true the led turns on. all i need is after 100ms turn the led off again. i'm having real difficulties coming up with a solution. the attached image shows i tried with Elapsed Time but it only works the first go-around and I can't figure out how to reset this timer to 0 at the beginning of the loop.
(3,553 Views)
I think I got it to work, although it may not be the correct approach, but if it works it works right?!
(3,526 Views)
Be careful with the exagerated use of local variables. Why don't you simply wire the "Numeric" indicator instead of using several read/write local variables for the same value?
I've made something. It's still not the best approach, but it's way more simple.
[EDIT: Today it's not my day. I'm having issues to attach an image. What I would do is to create a case structure: IF something is TRUE, then your led is true. Use wait(ms) to determine the delay.]
Mondoni
(3,504 Views)
Here's an option:
If your program is going to become more complex, consider using a state machine.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,456 Views)
HI,
Can you attach an image for the program? I am getting problems in creating one.
Thank You
(3,386 Views)
