setting the fixed-point type
How is the fixed-point type set on the "To Fixed-point Function" without manually opening the output configuration? There is input to this function, but LabVIEW Help does not indicate what value/s or format of the value/s to wire to this terminal to get a specific data type as the output. Any help would be greatly appreciated. Even a simple example would be wonderful. Thank you.
(3,306 Views)
Hi John,
well, the help mentions 2 inputs and one output of that function. Use the upper input to set the FXP type...
(3,302 Views)
I understand that the upper input is used to define the output data type. My problem is that the Help section does not indicate how to define the parameters of this input to get a particular output.
(3,295 Views)
Not too much to understand.  The output type is determined from the fixed-point type connection and the value from the number connection.
input     FXP output
U8        U8
I16        I16
U32      U32
etc
Or, if you prefer, you can set the same settings from the properties right click menu.
(3,277 Views)
