pulse width measurement
Much better with the DAQmx Task.
Wire "Data" directly into pulse measurements (you need the timing information!) and the pulse duration will be in seconds rather than in samples
Message 11 of 29
(1,864 Views)
Dear Jeff!
i try to do follow what u say! but i recieved ... no result!
this is my pic, show to u!
do u want my program ( *.VI)
help me! thanks!
Message 12 of 29
(1,860 Views)
It would be best to have the actual VI.  Be sure to save the front panel defaults before sending on (Edit->Make Current Values Default).
Message 13 of 29
(1,858 Views)
Check "Polarity" and "Export mode"
There isn't a full cycle of data so duty cycle can't be calculated
Message 14 of 29
(1,849 Views)
hii Crossrulz
i do that, but ... i have no more!
this is my program! help me check!
thanks!
Message 15 of 29
(1,842 Views)
hii Jeff
i check about that!
i have .... nothings, this my program!
help me
Message 16 of 29
(1,840 Views)
Message 17 of 29
(1,839 Views)
If you read the dt from the DAQmx data, what do you get.  For some reason, the graph has 0 for the dt when I change it to a control.  This could cause some problems.
Message 18 of 29
(1,834 Views)
I also found that you want export mode to be "no period and duty cycle" and the polarity should be "low pulse".
NOTE:  I only set the dt for the waveform because the graph was giving me a dt of 0.  Coming out of the DAQmx Read should have a non-zero dt.
Message 19 of 29
(1,831 Views)
Dear Crossrulz!
i know, i have many problem in may program! but i do not know how to correct that!
help me! i need to finish this next week!
thanks! because this is first time i do with labview!
Message 20 of 29
(1,829 Views)
