putting cursors on a strip chart
    I have inheritated old code that records and diplays temperature over a few hours time with 20+ channels.  I was hoping that there was a way to get a cursor on a strip chart that could display the x and y value at a given drag point of the cursor on the displayed data.  I know that the cursor pallet is available on the plots but not on the charts.  Finally, the way the data is broght in and handled a chart is the best way to display the data.  Using a plot would require significant re-write.  Any suggestions?
(3,168 Views)
I found an example that relates to this issue:
https://decibel.ni.com/content/docs/DOC-8464
There is also an explanation of two options you have to recreate settings similar to a plot/graph:
http://digital.ni.com/public.nsf/allkb/B1B0877A28D75D4086257592002F0AB7?OpenDocument
Applications Engineer
(3,133 Views)
Accepted by teslac
Thanks for pointing out where to find examples and resoloving this issue for me.
(3,109 Views)
Then please don't mark your thank you as the solution. You should change it to Skywalka's answer. To change, click on Options.
(3,103 Views)
