python shared memory object
  • Hello everyone, I have a puzzle to consult.
  • I created a shared memory object in Python and wrote data to the shared memory. Can labview read this data written by python?
  • I want to create a data sending and receiving area between Python and labview, and I wonder if it can be implemented this way.
  • Looking forward to your reply.
Message 1 of 24
(5,406 Views)
Accepted by hallo77
Being two different processes, LabVIEW and Python cannot share the same memory space. The Python node in LabVIEW does some level of marshalling/translation between the data spaces.
Better option, write to a file from Python, read that file in LabVIEW. You're not limited in data types and complexity.
Santhosh
Soliton Technologies
Message 2 of 24
(5,357 Views)
Thanks for your reply! This not only solved my confusion, but also provided me with valuable ideas. Thank you very much!
Message 3 of 24
(5,354 Views)
Accepted by hallo77
Personally I would be more inclined to use a server/client mechanism for passing data between the two processes. This provides a more flexible approach. You could use a JSON format for the data and that would ensure both sides would know how to interpret it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 24
(5,341 Views)
Thank you for your reply.
Yes, it's great idea. however, I want to construct a data sending and receiving area between Python and labview, Python keeps storing data in it, and labview periodically retrives data.I'm not sure can this be done through the server/client mechanism.
Transiting through text seems feasible, but it also has certain limitations. But I can't think of a better way.
Message 5 of 24
(5,330 Views)
Accepted by hallo77
Of course, that will be a better approach if you need both application transfer often and support variety of comms.
Santhosh
Message 6 of 24
(5,327 Views)
Providing more detail about the application, why it has to be Python and LabVIEW, what kind of data, how large and how often - these will help suggest better solution if there are.
Santhosh
Message 7 of 24
(5,324 Views)
Well, I want to create a host computer using Python and labview. Python to achieve communication and data processing, labview try not to add too complex procedures, mainly data display functions. But the transfer of data between them is a problem, do you have any suggestions? Thank you very much!
Message 8 of 24
(5,313 Views)
More about it.It's not a huge amount of data, a dozen of it, of the type uint16. What time does time mean? The data read time of the timer is about 200ms.
Message 9 of 24
(5,301 Views)
you can use TCP or UDP to interchange data over ethernet between a labview .vi or .exe and a python script.
Message 10 of 24
(5,296 Views)
