quadrature encoder measurment with labview 7.0 using M- series 6221 DAQ
I am trying to make position measurement with quadrature encoders using M-series DAQ 6221 with labview 7.0. I found an example code in ni.com but the code cannot be opened with labview7.0.. an error message appears telling that it needs version 7.1... Is any example code that can be used with labview 7.0 about my problem..?? thanks a lot..
(2,932 Views)
Hello ress,
If you post a link to the example, or attach the example itself, I'd be happy to save it back to LabVIEW 7.0 for you!
-Alan A.
(2,917 Views)
The code I mentioned was in the link below...
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=E4C7474E20790DDBE034080020E74861
thanks for your help... 🙂
(2,912 Views)
