queries regarding DMA FIFOs
I assumed that you were using one of NI's standard FPGA targets such as cRIO, R Series, or FlexRIO
What do you think is present inside the cRIO or anyother NI's standard FPGA Targets? Smiley Surprised
Spartan and Virtex are FPGA development boards manufactured by Xilinx.
http://www.xilinx.com/products/boards_kits/index.htm
The table below shows cRIO chassis number and corresponding FPGA Board.
Chassis
9072
9074
9101
9102
9103
9104
FPGA Chip
SPARTAN 3 1000
SPARTAN 3 2000
VIRTEX II 1000
VIRTEX II 1000
VIRTEX II 3000
VIRTEX II 3000
And FIFOs can be created on both these boards.
http://zone.ni.com/devzone/cda/tut/p/id/6983
Virtex-II 3000
Virtex-II 1000
Spartan-3 1000
Spartan-3 2000
Virtex-5 LX30
Virtex-5 LX50
Virtex-5 LX85
Virtex-5 LX110
 Total RAM (kbits)
1728
720
432
720
1152
1728
3456
4608
Blocks Size (kbits)
16
16
16
16
36
36
36
36
Memory Resources for Various FPGAs
Regards.
Message 11 of 13
(880 Views)
HI,
I'm working with a PXI-7833R so it's well defined.
In fact I've got a problem with the default 10000 element of the host DMA FIFO. I've never seen that so the behaviour was strange due to these elements.
I've changed my code and it's seems to work now.
Message 12 of 13
(869 Views)
David,
I fully understand these products as I develop software for them.  What is inside a cRIO that is not inside the academic eval kit (without getting into too much detail) is an NI ASIC that provides DMA support over a PCI bus.
Message 13 of 13
(860 Views)
