querry: caaling c code thru labview
Plz guide me regarding this problem....
i have called a c program using call library function node...that c
program reads some data from a file ....on doing so i encounter an
error during run time which says..debug assertion failed
program:\c:\program files\NI\labview7.1\lv.exe
File Fclose.c
line 58
expression : stream != NULL
then i get a message to retry cancel or abort
on retrying it shows send error message to microsoft
after all this when i try running my c file simply it shows file
cannot be opened
and now i cant open any file through a c program even those which were
running smoothly earlier...
why is this happening and how can this be resolved.....
thanks.........aparna
(2,790 Views)
(2,779 Views)
