query regarding signal hound Programmable measuring equipment
i have some query regarding  following products by  signal hound.
Spectrum Analyzer   BB60C
Tracking Generator USB-SA124B
Vector Signal Generator VSG60A
DM3058 by RiGOL
do all above mentioned get interfcaed with Labview for programming and analysis.
which versions of labview do they support ..are device drivers required for them or they will work with  visa read and write functions??
(2,541 Views)
The LabVIEW drivers for Signal Hound products were created in LV 2016, but if you contact them they will supply other versions. Quite frankly, the drivers are very limited to basic functions, and a bit tricky to get working. You are better off using SCPI commands with VISA read/writes. A list of commands are in their SDK downloads.
Here is a link to their LV drivers.  https://signalhound.com/software/signal-hound-instrument-drivers-for-labview/
(1,522 Views)
