sending commands to visa write
hello everyone.
i want to send mutiple command to via write using any loop not clusters as i did in attached vi. now i am using cluster to send the commands if i select case 1 one then it must send command 1 the case 2 the then 2nd if all three then all three commands should send. anyone has idea how to do it? im attaching what i have tried.
thank you in advance.
(1,831 Views)
Why build into a cluster?  You should build into an array and then it is a simple FOR loop to send the messages.
(1,822 Views)
please can you show me example or link of example so i can follow it?
(1,807 Views)
Something like this...
(1,798 Views)
