question about IMAQ 1394 for LabVIEW
When I tried to use IMAQ 1394 Sequence.vi
I found parameter seemed no use.
whatever value I give it. the vi acquire frames no skip.
(2,657 Views)
This is a known issue with the 1394 driver and will likely be fixed in the next revision. Here is a replacement VI that implements the same functionality.
Brent R.
Applications Engineer
(2,657 Views)
