Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
question about IMAQ 1394 for LabVIEW
John Smith
Member
08-16-2002
02:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When I tried to use IMAQ 1394 Sequence.vi
I found parameter
seemed no use.
whatever value I give it. the vi acquire frames no skip.
0
Kudos
Message
1
of 2
(2,655 Views)
Reply
Re: question about IMAQ 1394 for LabVIEW
Brent_R
Active Participant
08-16-2002
05:20 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
This is a known issue with the 1394 driver and will likely be fixed in the next revision. Here is a replacement VI that implements the same functionality.
Brent R.
1394SequenceSkip.vi 91 KB
0
Kudos
Message
2
of 2
(2,655 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
