question regarding calling a vi
I have a vi that calls a whole bunch of other vi's multiple times, one particularly that is very large.  I use the subvi method to call each vi and the problem i am having is that after I call the large vi once the next time i call it, it freezes my program and i cannot change anything.
To fix this problem i changed the call setup for only the larger vi to "reload for each call' and now i am not having that problem anymore however i was wondering why would i need to call the larger vi with 'reload for each call' while the other vi's can work on the default option, 'load with callers'.  Is there anything i have to watch out for when creating a vi so that i don't run into this problem
I would have attached vi's to demonstrate my point howver i cannot duplicate it
thanks
(2,482 Views)
Try checking out this KnowledgeBase article for more information about dynamically calling VIs in LabVIEW.
Amanda Howard
Americas Services and Support Recruiting Manager
(2,454 Views)
