questions on XY Graph
Hi, i believe many people have already asked this question, but i couldn't find solution to my problems below.
  1. i would like to plot multiple Y-axes on same X-axis (time) using X-Y Graphs . The reason i am using X-Y graphs is I have data (both amplitude and timestamp) in an array, so it would make sense to directly plot the arrays as it is rather than using a for loop to plot 1 element at a time.
  2. I would like to stack multiple Y-axes just like the waveform charts using X-Y Graphs, not sure if it is possible to do that?
Has anyone tried something like this before?
Now on LabVIEW 10.0 on Win7
Message 1 of 10
(5,132 Views)
Yes.
Right click your y-axis and choose "duplicate scale".
Expand your plots so you see at least Plot 0 and Plot 1.
Right click one of the plots and choose Y Scale as Amplitude 2.
Message 2 of 10
(5,121 Views)
Thank you, i know how to do that on front panel, how would the block diagram look like?
Message 3 of 10
(5,105 Views)
You just have to set it up on your front panel once and it is done. You can use property nodes to make plots visible/invisible or use the Plot.YScaleIdx (Y Scale Index) to choose which scale to use, but I imagine you won't really need to change it on the fly...
Message 4 of 10
(5,099 Views)
One of my favorites
An array of clusters of arrays of clusters.
Smiley Happy
Ben
Message 5 of 10
(5,091 Views)
@Ben wrote:
One of my favorites
Smiley Happy
Ben
That sounds very confusing, can you please share a picture of such vi?
Message 6 of 10
(5,080 Views)
Accepted by LV_Enthu
@LV_Enthu wrote:
@Ben wrote:
One of my favorites
Smiley Happy
Ben
No but I will ry to explain. Starting at the end of the expresion and working back to the left.
Clusters - a cluster with two values, an X and a Y. The cluster is a point to be plotted.
Arrays of clusters - the array is one of the plots on the graph.
Clusters of ... - LV does not let you do arrays of arrays (that would be a 2-D array) so each plot gets wrapped in a cluster.
An array of clusters of arrays... - Each array is one of your plots.
Ben
Message 7 of 10
(5,075 Views)
Thank you that helped...
Sorry i had another follow up question, can i stack these multiple graphs just like waveform charts?
If nt, is there a way to have 1 axis on left and other axis on right, just like excel?
Message 8 of 10
(5,069 Views)
I don't believe you can stack them. You can swap sides by right clicking the axis and selecting "swap sides"
Message 9 of 10
(5,065 Views)
Yes after doing what Greg described above you right-click one of the scales and select "swap sides" to move the scale to the other side of the graph. Greg also explained how to associate a plot with the proper Y-Scale.
Message 10 of 10
(5,063 Views)
