"Enable Enhanced DSC Run-Time support" is grayed out
I want to create a .NET Interop Assembly from a LabVIEW project.
In a first attemp, my Assembly crashed. After some research, this problem should be solved with the option "Enable Enhanced DSC Run-Time support".
Therefore I installed the LabVIEW DSC Module.
Afterwards the option "Enable Enhanced DSC Run-Time support" was visible but grayed out in LabVIEW 2017 (first screenshot) My Interop Assembly Properties _ LabVIEW2017.png
and LabVIEW 2020 (second screenshot).
The note in LabVIEW 2017 probably refers to TestStand.
After installation of TestStand I checked if "Enable version-independent LabVIEW Run-Time Engine" is unchecked.
I tried both checked and unchecked option in TestStand - but "Enable E. DSC RT support" stayed grayed out.
How can I make the "Enable E. DSC RT support" option available?
Do I have to install another module?
Is this option not available during the evaluation period of DSC?
Please let me know if you need any further details.
Thanks for your help,
Christian
Message 1 of 1
(1,498 Views)
