Connecting Labview to RS485
Hello everyone,
am using a temperature controller (eliwell 4822) with RS485 and am using also LabVIEW 2016 software , I want to test the controller's commands for the acquisition part . My project is to control edible oil temperature and make it stable .i'am a biginner I will appreciate any kind of help that you will be offering .
My email is: imene_7@outlook.com
Message 1 of 22
(6,975 Views)
Do you have a RS-485 port on your computer?  If not, then get a USB-RS485 adapter.  Most will show up in Windows as a simple COM port, which means you can just use VISA and standard serial communications after that.  However, that controller uses a MODBus protocol.  So look in VI Package Manager or vipm.io for a package that handles MODBus.  NI has one and there are a few others that could work for you.  After that, you need to figure out what registers you need to read to and/or write from to control your controller.
Message 2 of 22
(6,963 Views)
I recommend a USB to RS485 adapter with an FTDI chipset that installs a virtual Com port.
Then communicating with your instrument will be no different than communicating what any other instrument on a Com port.
=== Engineer Ambiguously ===
Message 3 of 22
(6,916 Views)
Hi ,
Thank you for answering , yes am using RS485 USB TTL , i will start the application as soon as possible and I will keep you updated thank you so much for your help I really appreciate it.
Message 4 of 22
(6,883 Views)
Hi ,
Thank you so much for all the informations ,  am using RS485 USB
I will let you know about my progress , I appreciate your help .
Message 5 of 22
(6,881 Views)
BTW: I took a quick look at your device and see it uses MODBUS
There is a free MODBUS library available through VIPM
It is very well supported in the NI LabVIEW Modbus API Discussion thread.
Message 6 of 22
(6,874 Views)
Hello ,
Am having communication problems with my instrument am using RS485 USB modbus protocol an LabVIEW 2016  amt to read registers (input, hold, colis)
Can you please give me all the details about the steps that I need to follow to reach my goal , I will appreciate any kind of help , Thank you .
Message 7 of 22
(6,824 Views)
Hello ,
Am having communication problems with my instrument am using RS485 USB modbus protocol an LabVIEW 2016  am trying to read registers (input, hold, colis) and communication with  internal registers
Message 8 of 22
(6,827 Views)
What are you having trouble with? What have you tried? Did you install the Modbus library as recommended by RTSLVU?
A quick google search comes up with this which provides some information, but doesn't have the register map that is normally associated with Modbus communication. You may need to contact the manufacturer and see if you can get that map. Once you have it it's simple to program with the NI Modbus Library.
Message 9 of 22
(6,777 Views)
Hey StevenD ,
Thank you for making time to answer,  am having trouble  with reading my regulator registers , yes i install the  modbus library and the PaletteMenu , what can I use from this two to be able to read only the regulator registers and to display the setpoint from Labview to the regulator that's basically what I want to do. I will leave some documents that maybe could help to understand more
 8MA10081_EW48_Modbus_EN_0410.pdf
How_to_communicate_with_Modbus_RTU_slave_device_in_LabVIEW
Message 10 of 22
(6,740 Views)
