"Evaluation Copy" is displayed on 3d Plot with runtime version of LV 8.5 Prof Dev Sys, how do I fix
Hi john4177,
Can you check if you have the following registry key on any of the affected computers: HKEY_CLASSES_ROOT\Licenses\CC157286-E7A0-4CDA-BF36-7BDDF4D54022
Jeremy_B
Applications Engineer
Message 11 of 14
(958 Views)
Problem solved.  I deleted the 3d plot and inserted a new one.  Now everything works fine including the installer on other computers.  Wish I had thought of that before wasting 3 days.
Message 12 of 14
(958 Views)
that key was not present.
Message 13 of 14
(956 Views)
Hi john4177,
I'm glad it is fixed.  I'll log this issue in our database in case it comes up again.
Jeremy_B
Message 14 of 14
(939 Views)
