"File Path Control" default Value
Hi - How do we set or change the default value for "File Path Control" (Control --> String & Path ---> File Path Control)?
I typed the default path into the control field on the front pannel and save the VI file.  The value gone when I reopen the file.
Message 1 of 19
(7,525 Views)
Right click on the control, go to Data Operations>>Make Current Value Default
Message 2 of 19
(7,519 Views)
How do we set to NOT valid the path value?
Message 3 of 19
(7,508 Views)
I would drop a Not A Path constant on the BD, right-click and Change to Control.  The default value is now set for you.
If you use Modern controls you can click on the % glyph and choose Not A Path, but I use System controls so that is why I go the constant route (plus the auto default setting is nice)
Message 4 of 19
(7,504 Views)
By the way, I realize I never paid attention that there's a difference between Not a path and Empty path... Why?
Message 5 of 19
(7,466 Views)
@Jimmy.chretien wrote:
[...] difference between Not a path and Empty path... Why?
Not a Path is a specific value for the path (<Not a Path>).
Developers should use this to prevent situations in applications, where a user has to select a path before performing an action (e.g. saving a file). If the user skips the path selection, the application still has "Not a Path" and can prevent errors and tell the user to select the path (error handling!).
Norbert
Norbert
Expert: Geometry
Message 6 of 19
(7,443 Views)
If it returns empty path, the developer can easilly do the same error handling, I don't see the point....
Message 7 of 19
(7,421 Views)
Not as easilly since an empty path returns F for the comparison
Message 8 of 19
(7,416 Views)
The empty path on Mac/Linux is the root of the file system.  When you write paths such as /path/path it is actually (empty)/path/path.  The upshot is that the empty path is perfectly valid on those systems and not really a useful sentinel value.  <Not A Path> is such a sentinel.
Message 9 of 19
(7,410 Views)
There is a "Empty String/Path?" function in LabVIEW.
Message 10 of 19
(7,400 Views)
