"File Path Control" default Value
As Darin mentioned, on other platforms an empty path is valid.  Try using the List Folders function with an empty path, what does it return?  A list of current drives.  If you provide a Not A Path it should error.
In my mind this is the same as supporting the NaN (not a number) for doubles.  Why support this when you could just have the default be a 0 and use the Equal 0? to determine if the user didn't enter anything?  Because 0 is a valid value for things, just like an empty path can be valid.
Message 11 of 19
(2,691 Views)
Why don't we have the Not a String value?
Message 12 of 19
(2,684 Views)
You are trying to be silly, right?
Message 13 of 19
(2,674 Views)
Empty String/Path? is right there on the comparion palette
Message 14 of 19
(2,669 Views)
I can't really see a purpose for it, or a use where I could use a string which has a value of "Not a String".  I'm guessing that's why one doesn't exist.
Message 15 of 19
(2,658 Views)
Usage would be the same as for Not A Path - to distinguish between an unwired terminal, and one that has an empty string wired to it.
Message 16 of 19
(2,652 Views)
I guess, but I'd just make the terminal required.  Now that I think about it I don't really use Not a Path all that often.
On a side note.  NI has written functions which can detect if something is wired to them or not, without reading the value.  Having this feature be available to normal developers would be nice some times.
Message 17 of 19
(2,647 Views)
VIA tests for unwired terminals.  Check hidden gems.  Or look in the shipped tests for the code.
Message 18 of 19
(2,629 Views)
Well, You simply make a special setinel value the default for the control, e.g. "<Not a String>" and test for that. If you get it, the terminal was not wired.
Message 19 of 19
(2,615 Views)
