"Fill to " in graph XY programmaticaly
Hello to all.
First of all thanks a lot for reading this post and being able to help.
I have an XY graph whit cursors (upper limit and lower limit). These limits are set by users in a control.
Now I would like to fill programmaticaly from upper limit to +infinite and from lower limit to -infinite.
How can I do that programmaticaly? Any property node?
Thans a lot!!
(4,750 Views)
Accepted by topic author A.Salcedo
Hi A.,
use additional plots in the graph, one for upper, one for lower limit.
Change their properties to the desired fill behaviour…
(4,747 Views)
Yeah what GerdW said.  Here is an example.
(4,709 Views)
2 little things:
Limits can be 2 point arrays not to waste data
If their x ranges are infinite, graph x will not autoscale on them and they will cover full graph.
(4,695 Views)
Great improvements, especially the scaling thing.  I didn't try zooming out, but if I would have, then I would have seen the limits are only the same X that I provided.  Your solution works much better for this.
(4,689 Views)
Great! Thanks a lot!
(4,647 Views)
Yeah very good!! You all help me so much!
(4,646 Views)
