"In Port" for parallel port under Windows 2000
I have written a Labview application that acquires data using a PC's
parallel port.
It works perfectly under Windows 98, however I am having some
difficulty getting it to work with Windows 2000.
I am aware of the usual problems and have installed hwaccess and
switched to using the parallelnt.llb versions of "In Port" and "Out
Port".
The behavior that I am observing is that when my program calls "In
Port", passing it the address of the parallel port, "In Port" is
sometimes returning values such as 65535 and 65530. I am expecting a
byte, not a word, to be returned from "In Port" as this is documented
to be the default behavior. Explicitly specifying a byte makes no
difference and as I said it works with Windows 98
Any advice that anyone can offer would be appreciated.
Stephen
(3,028 Views)
Is it possible the function is returning an error code of 0xFFFF/0xFFFA to indicate there is a problem with something?
(3,028 Views)
What version of LabVIEW are you using?
Have you tried using the accessHW replacement VIs?
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3DEBD56A4E034080020E74861&p_node=DZ52058&p_submitted=N&p_rank=&p_answer=&p_source=External
(3,028 Views)
Hello David,
David Duffey wrote in message news:<50650000000500000067140100-1042324653000@exchange.ni.com>...
I am using Labview 6.1
Yes, I am already using the replacement VIs.
I am really stuck on this one so any advice as to what might be going
on would be appreciated.
I should also perhaps add that the parallel port is in EPP mode.
Stephen
(3,028 Views)
m3nth wrote in message news:<50650000000500000057140100-1042324653000@exchange.ni.com>...
Not as far as I have seen in the documentation. Also I receive other
values which don't relate to the data that I expect to receive.
Cheers,
Stephen
(3,028 Views)
Hi, stephen,did you solved you problem. I met the some problem similar what you have, and have the same system. my problem is that the inport is not working at all. It pop out an window " the vi was stoped at nod 0x1D8 of subVI "in port.vi"". How can I do?
(3,028 Views)
Stephen,
Have you solved this problem yet?
I alsohave the same problem and have also installed AccessHW VIs. These however don't work with a CVI runtime engine later than version 5.5.1 see http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/8566c7f0fc169bf686256cd40076533a?OpenDocument .
I have not tried this yet but hopefully it will solve my problems
Leeser
(3,028 Views)
