"LabVIEW PDA - Palm OS Hardware?"
I'd like to get some feedback on what Palm OS PDA's are being used in conjunction with the LabVIEW PDA software. I've been tasked with creating a very compact application for monitoring a system, and we're interested in doing this through a Palm PDA (I chose Palm simply because I used to write Palm applications a few years ago, and I'm pretty familiar with their system). We have a DAQCard-6062E that is used in a laptop at the moment, but for this application, that's just overkill. I'd like any input from users on the following:
1. What type of Palm PDA (model number) are you using with the LabVIEW PDA software?
2. What type of cradle (model number, etc.) that goes with the Palm PDA for a PCMCIA card? Also, where can you get this cradle?
3. Interface cable preferences? (length, type, etc.)
Thanks for your input,
tsc
(2,614 Views)
Hello –
Palm M-series or Tungsten supports a DAQ device. CEC sells these DAQ devices with a sleeve and you just have to put the Palm device on it. Also, they will provide you with a driver that will allow you to communicate with LabVIEW PDA for Palm.
Go to this link. Click on Data Acquisition, then on pdaDAQ/100.
Hope this helps.
SVences
(2,603 Views)
