LV Example for performing Excel Solver function
Excel Solver can find the coefficients a, b, and c in equation y=a+b*(x^c) easily by given x(i) and y(i).
I wonder if the LV 7.1 can do the similar thing. Is there an example available? Thanks!
(4,463 Views)
You can use the Non-linear Lev-Mar fit.vi (in the Analyze>Mathematics>Curve fitting sub-palette).
You have a series of shipping examples in National Instruments\LabVIEW x.x\examples\analysis\regressn.llb
Read also this discussion
CC
Chilly Charly    (aka CC)
(4,450 Views)
I have looked and tried the examples in National Instruments\LabVIEW 7.1\examples\analysis\regressn.llb. They are not well documented nor fitted my equation. I would like to see if NI or someone can show me how to call the functions and get the soulution. Thanks!
(4,427 Views)
Hello A3J,
The curve fitting express VI available from Functions->Signal Analysis should be capable of giving you the coefficients you desire.
Please let me know if you have any questions.
Matt F
(4,396 Views)
May be you could try a little bit harder..:)
See the attached vi.
CC
(4,394 Views)
Hi chilly charly,
Your example works very well. Thank you very much!
(4,359 Views)
