"Log" functionality of serial VIs logs the irrelevant
Call me old-fashioned but I thought that in running app'ns built from std VIs such as 'LV-Serial' & 'Serial-read-with-timeout' selecting 'log' and specifying a file associated with this meant any serial-data caught on screen would be piped into the file rather than the on-screen settings/labels at the moment of the serial-catch-attempt being recorded. Is this possible to change?
(2,434 Views)
Simon,
Logging, the type described from the Operations menu is there to log the values of the front panel items to a text file for later retrieval. You can log once when the VI completes (great for viewing subVI test results at a later time) or interactively. It is not meant as a redirection system. That kind of functionality can be programmed into the VI using case structures and a boolean switch.
For more information, look up 'datalogging' in the LabVIEW Help.
Randy Hoskin
http://www.ni.com/ask
(2,434 Views)
