"Map to local Machine" option is disabled for PXI-7344 motion device
I'm trying to configurate a PXI-7344 motion device that is installed in a PXI-1011 chassis controlled by a PXI-8176 RT controller. It is installed Motion RT v6.0 and MAX 3.0.1, and correctly downloaded into the controller. The device is detected using MAX under the Remote systems - IP - Devices & interfaces folder; but when I make right click over the 7344 device the option ·map to local machine" is disabled, so I can't configure the motion device. On the other hand, the other devices and SCXI devices are properly detected and it is possible to configurate them.
(2,540 Views)
It may be that you have already chosen to map the 7344 to the local machine. That was the case for me - I have a PXI 7344 and PXI 7350, where the 7344 was already mapped to my local machine, and the option to map to local machine was grayed out. Try pressing F5 to refresh MAX and then check under the main Devices & Interfaces tab for the PXI-7344 on IP address.
Hope this helps.
-Julie
(2,540 Views)
