"Performance" of Simulated Devices
Hello all,
I did not have access to my DAQ hardware today, so I experimented with using Simulated DAQMX devices. I built a simulated device and plopped a DAQ assistant down into a blank VI and set it to continuously acquire a voltage at 1kHz. I set the number of samples (i.e. buffer) to 100 samples. I put this inside a For Loop (10 iterations) and plumbed the DAQ assistant to a TDM storage file. After running the VI, the file indeed shows 1 second of "captured" data, which I interpret as 10 pulls from the buffer. However the code ran considerably longer than 1 second (ballpark 5s-10s)
So my question(s) is this : Do I have fundamental misunderstanding of how to properly use the DAQ assistant? Would this have run quicker on my actual DAQ rig (M-series installed in a RT Target) instead of a sim'd device?
Thanks in advance for humoring a newbie...
Matthew
Mech. Engineering Dept.
NC State University
Matthew Pausley
NC State University
Raleigh,NC
(3,228 Views)
Accepted by mepausle
hi there
i just created a VI like you described it and tested it with my real and a simulated device. the real device took about 1000ms for 10 x 100 Samples @ 1000 Hz. The simulated device ran about 25 times FASTER than the real device, though the acquisition settings are the same...
so i wouldn't trust that much in the timing behaviour of simulated devices (to be honest, i think that wouldn't be a easy job to simulate the timing in all cases...)
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,197 Views)
I'm getting similar performance from some VIs I'm running today.  The while loop is set to run every 5 msec.  I have a display counting up seconds.  It seems to be running long (I can count seconds myself and get a higher number than this display).  I would think that it was wrong, except that my PID Setpoint Profile generator is changing setpoints exactly on schedule.
Maybe the counter in my head done be broked.  Smiley Very Happy
Go Pack!
(3,192 Views)
