"Prompt user for input" 2D array
Hello everyone,
I try to click a button and prompt a dialog box for user. However, when I use the event structure and "prompt user for input", I find that the input data type is only number, checkbox, and text. I want to input a 2D array which is a flow rate-time profile. Can you give me some advice, Thank you.
Qun
(4,029 Views)
There are missing VIs, and no event structure is in the code posted.
If you want to prompt the user with a 2D array of data use the Table control in a new VI set to be the dialog type in the VI Appearance.
(3,995 Views)
Accepted by chalkwu
You can use the "Dialog using Events" template which ships with LabVIEW.  This is a good starting point. use File >> New... and select the template.
(3,986 Views)
Thanks for your help Hooovahh Smiley HappySmiley Happy
(3,954 Views)
