 littlesphaeroid
			littlesphaeroid
			02-10-2016 05:07 PM
Here's the setup: I'm making a VI that duplicates a test template (vilib) and it's associated build specs within a project. My idea is to have a VI that the user (developer) opens and which presents a dialog (select template, enter name of new test, GO). Ideally this VI will simply run when opened.
If I create a VI and set it's execution proerties to "Run when opened" and open it from the OS's file browser, the VI behaves as expected: it runs. If I open the VI from anywhere within a Project, it does not. Why would this be? Is there a workaround?
Solved! Go to Solution.
 Gregory
			Gregory
			02-10-2016 05:54 PM
I noticed the same behavior. You can right click the VI and press Run
 mikeporter
			mikeporter
			02-10-2016 06:10 PM
02-10-2016 06:31 PM - edited 02-10-2016 06:33 PM
HI Mark, thanks for the snarky reply! I'll ignore that and go on to say this is not the expected behavior according to my expectations. Your rhetorical question would apply to a VI opened from the finder: how would you edit it? You'd stop the VI from running and switch to edit mode. Did you have in mind that once a VI is running it can no longer, ever, be edited? That would be strange behavior indeed.
What difference does it make if I open a VI from a project of the OS? I'm *opening* it.
 Dennis_Knutson
			Dennis_Knutson
			02-10-2016 06:36 PM
 mikeporter
			mikeporter
			02-10-2016 06:49 PM
 tst
			tst
			02-11-2016 02:12 AM
I don't know about expectations, but I do know that I personally don't much like auto-running VIs. Rather than go that way, I would suggest you integrate the VI into the LV editor like other tools do.
One way to do this would be to place it in the Tools menu and you can see some details here - https://decibel.ni.com/content/docs/DOC-5957
Another would be to integrate it into the right click menu in the project, but for that you need to create a project provider, which is more complicated and requires some coordination with NI. There's a dedicated group for that in the communities area.
02-12-2016 01:41 PM
Thank you Gregory, this is the only answer that gets me anywhere. It still does not explain why Run when opened doesn't work from a project, but it does help to know it's possible via a workaround.
02-12-2016 01:49 PM
Dear Mike,
Telling the truth isn't snarky. What is snarky is telling people that their expectations are incorrect. Snarky is taking a high handed and arrogant approach to others. I have a PhD and 20 years experience in the work world, and I don't deal with people in my daily life who treat me with disrespect and unkindness. And you, dear cupcake, did not provide an answer to my question or an explanation of why you think my expectations are wrong. Either would be welcome. Anything else is clogging the discussion.
The question remains: why is opening a file from the project different than opening a file from the OS? Why would NI provide an option to "Run when opened" if this did not describe the expected behavior? What should a developer expect this option to accomplish, if not to run when opened? Under what circumstances will this option have the expected behaviour.
These are all the same question, and a reiteration of the original question, which remains unanswered. I suspect that the designer of the functionality would need to tell us. I am not omniscient in that regard. But cupcakes think they are.
 Hooovahh
			Hooovahh
			02-12-2016 02:38 PM - edited 02-12-2016 02:41 PM
Alright lets take a deep breath...
Disclaimer, the following text is my opinion based on my knowledge of LabVIEW and not the inner workings of NI, I could be wrong about why decisions were made:
This feature in my opinion was put in many years ago, as a cheap and dirty way to make it appear as if a VI is executable code (which is sorta can be but shouldn't be treated exclusively as). Years ago if you had some code and you wanted a user to double click an icon and have it start running you would make an EXE. Well that required the application builder which was extra money and it was a decent amount of steps involved. The new users of LabVIEW complained that this was too difficult and wanted a way to just double click a file and have it run so NI added this function. NI also tried making it easier to do by adding additional items in the Tools menu to eliminate steps. Now if you double click a VI with nothing else open, which had this run when opened setting on, it would open and run it in LabVIEW. Running source code as an application has several pitfalls and issues, and in other (non scripting) languages this would not be tolerated. But it was a hacky way to make the beginners of LabVIEW happy.
Later on LabVIEW got projects and a easier way to make EXE (still requiring the application builder). Now using source from a project, looked and behaved more like source from other text based languages. In this regard opening a VI would be the equivalent of opening a text file in notepad. And having the behavior of opening text and having it automatically start running from your source would be a bad thing. The state of source can easily be modified which is one of the reasons binarys should be used in these situations.
So for the most part this feature is old and busted. It probably shouldn't exist at all, and the fact that it does exist stems from NI bending to the will of those who might not know what was best for the language as a whole. That feature should either be removed all together, or be updated to run when opened from a project which I hope I made clear is probably not the best solution. A third option would be to just update the documenation stating the current behavior.
If you want to run a VI when opened use this feature, but open the VI not from the project. Instead just open the VI from your file explorer, or from File >> Open in LabVIEW. Opening it from a project is telling the IDE you are trying to edit the source, in which case it shouldn't run when opened.
The good news is NI has a place where you can suggest new features or improvements for LabVIEW. If there are people who agree with your new idea they kudo it, and enough kudos causes NI to consider these features. If this is important to you, and a suitable work around doesn't exist I'd suggest making a post there.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
