"Save measurement to file"-VI doesn't obey the "Use next avaible file name" setting
I'm using this express VI to store data. In it's properties, there's the "If a file already exists: Use next avaible file name" radio box which does not work. Instead, it appends everything to the one file it created on the first run. My VI has a while-loop with an embedded flat sequence with the writing-VI being in the last frame of the flat sequence. LV 8.5, Linux
Message 1 of 16
(3,047 Views)
Hi There.
Could You make a screendump of Your VI?
I tried using the Express VI on both LV7 Express (Base,Win), and LV8.5 (Base, Win) , and it works perfectly....
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 2 of 16
(3,043 Views)
I've attached my VI. Currently, the save-VI gets it's file name from some other VIs, but I do that because it doesn't work otherwise. When I clear the "Filename"-input, it starts appending.
Message 3 of 16
(3,036 Views)
Hi ReBoot
I think i've found the Source of Error......When You generate the filepath You use a Concatenate strings with a Constant stating "Files/file" the problem her is the "/". It might be that it should be a Backslash "\"......
Try it....
Best Regards BCL
But there's NOT
LabVIEW 2012-2017
Message 4 of 16
(3,026 Views)
No no, everything's fine as it is. The problem starts when I remove the Filename-input from the Save-VI. Then the Save-VI refuses to take the next avaible file name. However, I'd like to be able to remove all this filename-code and let the Save-VI handle all the file naming.
Message 5 of 16
(3,014 Views)
Hi ReBoot,
how should you filenames look like?
Mike
Message 6 of 16
(3,010 Views)
That doesn't matter as long as they're indexed.
Message 7 of 16
(3,005 Views)
Hi Again.
Unfortunately i cannot run You Vi, because of missing Hardware, But if i Copy the Express VI to a new VI, and run it, it generates a new file everytime.
Try running the attached example.......Do You see the same behavior?
/BCL
But there's NOT
LabVIEW 2012-2017
Message 8 of 16
(3,003 Views)
Hi ReBoot,
why do you change everytime the filename? if you connect everytime the same name it should work.
Mike
Message 9 of 16
(3,000 Views)
It does not work because the problem I mentioned in the OP occurs.
Will try the uploaded VI!
Message 10 of 16
(2,995 Views)
