"Select All" button implementation in tree control
Attached is my LabVIEW 2019 SP1 (64-bit) tree control application VI. Instead of using Ctrl or Shift key to select hundreds of Item Codes to either add or remove, I just click on the "Select All" button, then all Item Codes are highlighted in blue, ready for addition or removal.
How do I implement this button?
(2,175 Views)
Accepted by topic author cha@bellflight.com
You could implement this with the two tree properties "All Tags" and "Value". Both are type String[] so you can just read the All Tags property and feed the output value into the Value property which will select everything (for a tree the value represents what is selected).
(2,167 Views)
Thanks for your help, Jacobson,
Attached is the solution.
(2,108 Views)
I made a set of code for doing multi tree and listbox selection with the checkbox glyph here.
https://forums.ni.com/t5/Community-Documents/Listbox-Multicolumn-Listbox-and-Tree-Item-Selection/ta-...
In it I have a right click menu for Select All/Select None, and Invert Selection.
(2,049 Views)
