"Start Asynchronous Call" as it should be
I never liked having to do this:
I submitted an idea (here) to have it be like this:
But nothing happened.  So I made my own.  Drop this XNode on your block diagram and you have a nice asych call.
Message 1 of 52
(5,378 Views)
That looks awesome! I'm on LV 2016 so I couldn't open it, but just out of curiosity: could you use option 0x40 to launch clones? Is the "close VI reference" inside the XNode? I notice you also have a reference as an output.
Message 2 of 52
(5,368 Views)
It has 2 modes:
  1. "Call and Forget" which opens with option 80 hex starts the VI, and closes the reference (hence having no ref out).
  2. "Call and Collect" which opens with option 100 hex, and outputs, rather than closing, the reference.
Here is a 2016 version.
Message 3 of 52
(5,356 Views)
Nice work!
I think I am missing something though, when I use Call & Collect the reference to the Wait On Asynchronous Call vi is broken. Should I be using something else?
Cheers,
mcduff
Message 4 of 52
(5,344 Views)
@mcduff wrote:
Nice work!
Cheers,
mcduff
Looks like I broke it somehow on my final cleanup.  A fixed version is coming soon.
Message 5 of 52
(5,338 Views)
Here it is, fixed up.
Message 6 of 52
(5,298 Views)
Thanks.
One last quick question, do you keep these XNodes in your user library or is there another preferred place for them?
Cheers,
mcduff
Message 7 of 52
(5,292 Views)
We keep them in a folder of commonly used VIs (not on C:).  I'm not sure if there's a 'proper' or best place for XNodes.
Message 8 of 52
(5,287 Views)
In my opinion they behave just like classes.  A single file which is a library (xml), which references other files needed.  With that type of definition I'd say any place a class is stored is appropriate for an XNode.  I'm a big fan of VIPM and as a result I generally make packages which install XNodes on the palette.  BTW this XNode is awesome.
Edit: and yes I do get an email every time someone says XNode on the forums.
Spoiler
XNode XNode XNode XNode XNode XNode XNode XNode XNode XNode 🙂
Message 9 of 52
(5,283 Views)
Spoiler
Do you ever have trouble getting XNodes on the palette?  I often have to jump through hoops to get them on a palette (though this one doesn't give me any trouble).
Message 10 of 52
(5,276 Views)
