"Start Asynchronous Call" as it should be
@Hooovahh wrote:
Listen I can make all the packages we want I just think Paul has several worth highlighting and it might make more sense to have a Paul's Favorite XNodes package which has a bunch of these rather than a package for each XNode.  I wouldn't want a palette for each array function for instance.  This is a bit larger of a request but one I can still help out with.  I'd just need a list of XNodes Paul things is ready for public consumption.  I think I can find most he's posted.
If you do that, I will create fake profiles just to give multiple kudos.
mcduff
Message 21 of 52
(1,740 Views)
@paul_cardinale wrote:
I'm not sure what you want.  This statically references a VI; but there's no such thing as a static reference to a clone.
I think they mean something like this:
https://forums.ni.com/t5/LabVIEW/building-an-executable-with-vits-with-Labview-2011/m-p/2384984#M740...
In that example I show using a static VI reference to spawn N clones of a VI.  For that to be used with Call and Forget you OR 0x40, with 0x80 to get 0xC0.  This only is possible if the VI is reentrant, and if the options are set properly.  In your XNode they are hard codded to either 0x80, or 0x100.  Basically I think the best option to do this would be to add a right click option on your node that ORs with 0x40 if set to reentrant, and then doesn't if it is off.
Message 22 of 52
(1,737 Views)
Side note: the use of 0x40 is widely misunderstood.  You don't need it to create a reentrant clone, and it adds needless overhead.
Message 23 of 52
(1,735 Views)
That won't be necessary but a Texas tea at NI Week will do Smiley Happy
Attached is a package with 3 of Paul's XNodes in them.  Very minimal cleanup effort but it has a proper icon for the palettes, and a bit more documentation in the package.  Also there was a few VIs named the same and I had to relink to just one copy, they all were the same code.  Oh and it is for 2018 because one of the VI sources was 2018 but back saving to 2017 is possible.  Earlier won't work since one of them contains a VIM.
Message 24 of 52
(1,732 Views)
@EricR wrote:
@paul_cardinale
Are you open to a discussion with me about allowing NI to just ship this code?  Either as an example or as a palette add/replacement?
eric.reffett@ni.com
Note that "Start Asynchronous Call" has a property called "Static VI Path", but it doesn't do anything.  But this does suggest that a one time, NI was at least considering this functionality.
Message 25 of 52
(1,713 Views)
I can find them all :).  But not everything in my pile is suitable for sharing.  And some of my early XNodes are a bit lacking.  But I'll see if I can put together a collection of fun and useful XNodes.
Message 26 of 52
(1,723 Views)
mcduff
That won't be necessary -- I'm reasonably confident that enough Forum participants who can appreciate Paul's contributions will be hitting the Kudo button ...
Bob Schor
Message 27 of 52
(1,698 Views)
Here is Version 2.  I remember making the following updates:
  • Fixed text in help
  • Fixed Help icon (shows up on palette)
  • Fixed spelling in menu
  • Added "Reentrant" option
  • Added "Relink to VI" menu item
  • Now accepts drop of a static VI ref
  • Now auto-updates when linked VI changes in memory
  • Should be backward compatible with instances of previous version
Message 28 of 52
(1,692 Views)
Here are some others you might like:
Message 29 of 52
(1,689 Views)
More Xnodes:
And Index and Unbundle (I never made Help for it.  It's the complement of Index and Bundle)
Message 30 of 52
(1,687 Views)
