"Sub-VI's not executable" when running Labview 2012 LLB files. I am using Labview 2014. I was told that I have to relink the "DLL"l file to each sub-VI to fix the issue.
Is this true? If so, what is the process of re-linking the .dll to the VI?
thanks.
(3,124 Views)
What sort of VIs are you talking about? What is the dll that you need to link to? Have you right clicked on the Call Library Function Node?
(3,116 Views)
thanks for the reply.
I'm calling the comCom.dll and I used the Call Library Function Node to configure the right path for the .dll file. But vi still won't run.
please see attachment for screenshots.
Is it because I'm using only the Labview 2014 evaluation to run the vi?
(3,059 Views)
Are you sure that function name is correct?  It looks like a junk name to me.
GCentral
(3,054 Views)
It most likely is correct. This is the name mangling you get when you use a C++ compiler and don't explicitedly tell it in the source code to use standard C naming conventions. The descriptions from the OP are vague, but it may have to do that he installed LabVIEW 64 bit and the DLL is a 32 bit DLL.
Rolf Kalbermatter  My Blog
(2,973 Views)
