"The VI is not executable."
I have an executable that runs on my development system and after installation on the target system gives the attached "This VI is not executable." message.  This executable runs on other PCs of similar type.
Per other postings, I have updated the .NET framework of the target to match my development system and I have unchecked the "Remove unused polymorphic VI instances" checkbox.
I still get the same "maddeningly unhelpful" message.
This is a very simple VI that just checks the operator input against a log file to prevent duplicate serial numbers being entered, and then launches another program via the command line.
Any ideas?
Dennis
Message 1 of 21
(5,252 Views)
Sorry, I don't have a solution, I just wanted to point out that you probably broke some record here:
Your image has about 100bytes of useful information, but your attachment is ~1.5MB, or about 15000x too big. 😮
Message 2 of 21
(5,226 Views)
Does your development machine have multiple version of .Net on it? If so, NI will automatically use the latest version. We have run into this in the past when multiple version of .Net were installed. You can force which verson to use by including a file named "<application name>.exe.config". The contents would be the following:
<?xml version ="1.0"?>
<configuration>
   <startup useLegacyV2RuntimeActivationPolicy="true">
      <supportedRuntime version="v4.0.30319"/>
   </startup>
</configuration>
Simply make sure that the version corresponds to the correct version of .Net you want to use.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 21
(5,218 Views)
Yeah, I should have typed in the message rather than attaching the picture.
"This VI is not executable.  The full development version of LabVIEW is required to fix the errors."
Message 4 of 21
(5,192 Views)
No, I only have .NET 4.0 on my system and I installed 4.0 on the target system.
Message 5 of 21
(5,191 Views)
Is the Run-Time engine installed?
Ben
Message 6 of 21
(5,184 Views)
Oh yes, as part of the installer, the Run-Time Engine is installed.
LabVIEW 2012f3 by the way.
Message 7 of 21
(5,179 Views)
I should mention that the VI runs on other PCs, but not on this target.
I thought it was a memory issue since the target system only had 512MB of RAM installed and the other PCs have 1GB of RAM.  However, installing 1GB did not help.
Message 8 of 21
(5,178 Views)
Does the target system have other versions of .Net installed? We would see this error fairly often until we started to include the config file with our installs.
Mark Yedinak
LabVIEW Champion
Message 9 of 21
(5,162 Views)
Bitness?  (developed in 64 deployed to 32?)  1/2 G RAM on the target begs me to question the OS's of both the development and target machines and the LabVIEW RTE / IDE (x64/x32) versions
Message 10 of 21
(5,149 Views)
