"The VI is not executable."
What kind of processor does this computer have? (I am not quite sure what you mean by "similar type")
Remember that for targets with relatively old CPUs (e.g. Athlon XP or pre-Pentium 4 intel), you need to disable SSE2 in the build specifications. By default, SSE2 is enabled, so the code will not run on these old processors. (See also).
(Just another idea. I am actually not sure how the error would look like in such a case...)
Message 11 of 21
(1,909 Views)
All 32-bit
Development system is Win7
Targets are all XP Sp3
Message 12 of 21
(1,903 Views)
@hartzde wrote:
All 32-bit
You still did not mention the exact processor model.
Message 13 of 21
(1,900 Views)
Duplicate
Message 14 of 21
(1,900 Views)
Development is a Core i7.
The Program runs on an "x86 Family 6 Model 15 Stepping 11"
The Target is an "x86 Family 15 Model 4 Stepping 10"
Per System information.
Message 15 of 21
(1,888 Views)
Thanks, I think this is a P4, so it should be OK.
Message 16 of 21
(1,879 Views)
I unchecked the SSE optimization and rebuilt the program and installer.
This did not change anything.
Message 17 of 21
(1,874 Views)
Did you ever fix this problem, hartzde?  I am having/have had this same problem and I can't seem to remember how I fixed it before.
Matt
Message 18 of 21
(1,803 Views)
Hello Matt,
It may be better to start a new discussion forum regarding the error and explain the steps that you have tried in order to get more feedback.
I would see if you are able to run the executable on any other machines?  Verify the correct Run Time Engine is installed.
Also check out this article: http://digital.ni.com/public.nsf/allkb/F715F1ED66878F8E862574F8006AD6A1?OpenDocument
M. Whitaker
ni.com/support
Message 19 of 21
(1,773 Views)
Thanks, Whit-E_Wall-E.
I realized that I had already posted in another message with the same title.  I won't rehash my own issue and the solution here (you can go to the link above to read more about it - I was able to resolve my problem in a similar fashion), but it would still be nice to hear from the original poster whether they were able to resolve this.  It would provide further insight into what might cause this issue as it seems the article you referenced did not provide a solution for his problem or mine and this is the only article that actually references the error.
Cheers, Matt
Message 20 of 21
(1,758 Views)
