09-01-2005 08:15 PM
09-02-2005 01:14 AM
09-02-2005 02:06 AM
09-02-2005 07:21 AM
09-02-2005 07:27 AM
09-02-2005 11:20 AM
09-02-2005 02:00 PM
a real problem!
your explanations are quite clear, but I don't know the answer.
just a guess: do you have several copies of DSc on your hard drive? I mean using several different locations on your hard disk for reinstalling the DSC module each time you reinstalled that. if so, delete extra copies. I had had a similar problem sometime times later (but not quite similar) and it was solved by deleting duplicated files (note that this was a completely personal experience!)
"WIN Get Window RefNum.vi" is a building block vi of DSC. I think that there is a problem with your installation.
another Q: can you start tag engine separately? any error?
09-02-2005 02:55 PM
09-02-2005 04:33 PM
09-03-2005 03:12 AM
Are you able to launch Tag Monitor from the menu?
Tag Monitor is a separate utility. I believe it's filename is tagmon.exe. You can search for it on your computer and try double-clicking it. Of course, the problem remains -- launching using the VIs, unfortunately.
-Khalid
